06 Dec 2006, 18:44
Hi all,
My drivers side door could use an adjustment to let it close as easily as the passenger side and bring it out slighty at the front so the black trim line meets flush.
Any easy tips on this, i have tried unscrewing and moving the door striker pins but cant get it sitting as good as i want the door to.
Also the bonnet sits a bit high beside the windscreen and above the front fenders. I notice that under the black plastic trim which runs along the inside of the trunk on the passenger side, there is more washers, about 5 or 6 on each bolt. Less on the other side.
What is the best way to get your bonnet sitting flush?
