28 Jun 2008, 22:51
Pages: 1 2
A Van
28 Jun 2008, 23:17
Think its a Pioneer.....
29 Jun 2008, 10:37
A Van Wrote:Think its a Pioneer.....
Good spot both Alistairs
29 Jun 2008, 15:54
I have put fuel in but the distributor is leaking around the centre gasket and the engine isn't firing. It does however turn over. I will have to check the injectors for fuel. Not sure wat has to happen the distributor as wel to stop it leaking. From an email in the workshop manual I can see he was having problems with the car starting but then stalling. He seemed to think it was fuel pump related.
29 Jun 2008, 16:17
Is it leaking from the fuel distributor ?
Whereabouts on it?
If it is between the 2 halves then you will more likely require a replacement, although Jason Monk is trying on a way of re-sealing them. Ask Tourettes to get in touch with him.
Good luck,
Nick.
Whereabouts on it?
Good luck,
Nick.
29 Jun 2008, 16:25
It is from between the two halves. I'll order a new one anyway. The fuel pump should be OK if the fuel isgetting this far shouldn't it? I can still test the injectors with the distributor leaking as well can't I?
29 Jun 2008, 16:31
In practise you could but be very careful and at least have a fire extinguisher and hosepipe at the ready. I personally wouldn't due to fire risk.
29 Jun 2008, 16:51
I'll leave it for now then. Sent Ed an email for prices and availability of parts. I'll tackle the many cosmetic jobs that need done first and catalogue the spares I have to place them on Ebay
29 Jun 2008, 16:55
mnickels Wrote:I'll leave it for now then. Sent Ed an email for prices and availability of parts. I'll tackle the many cosmetic jobs that need done first and catalogue the spares I have to place them on Ebay
Put an ad in the 'wanted' section, there may be a spare oem working one about you could try with all these volvo conversions.
A Van
29 Jun 2008, 17:09
Isnt there an o ring or something that seals it?
The previous guy may have had off to try and find the fault, and refitted incorrectly.
29 Jun 2008, 17:17
It is seaping from in between the two halves. He prob did have it off as all the fuel lines were off it
29 Jun 2008, 17:17
A Van Wrote:Isnt there an o ring or something that seals it?
Not for the 2 halfs of the fuel distributor.
There is an O ring underneath that seals air between this and the ventury.
Looking at:
http://www.deloreans.co.uk/forum/viewtopic.php?t=2073
there appears to be some O rings for the small filters.
Let's hope Jason has had some success in fixing one of these things
Pages: 1 2
