15 May 2008, 14:00
Hi Guys,
Long time no speak, currently trying to get through a degree and work full time. Big appologises
My car is working correctly, after many attempts to get it setup. Nick T is an inspiration, THANKS.
I'm looking over the course of the summer to collect the parts for a stage 2 engine, and create a completely seperate engine. This way I always have a spare to go back to. With the exception of the sandwich plate which will need to be donated.
I hopefully should be able to get hold of a volvo 260 engine within the group, (Chris Williams) which is the same block, but as standard has domed pistons, so more power.
I will then need to get the volvo venturi for it, larger diameter and fuel distributer. This is where the rummage comes in. Does any have any sources for a venturi (volvo - larger opening) and a metering head from volvo. Come on NickT.
Anyways, any suggestions would be welcome. Want it to look standard, but have atouch more poke.
Stainless steel free flow is the light at the end of the tunnel, but currently the tunnel is pretty long.
Cheers guys
Richard
Cheers guys
Richard
