hi all
does any know were i can either get my hands on the pannel that every one knows come loose when you get into your delorean it some times come apart from the orignal panaling on the lowe pannel at the back of the driver door( little grey or back pannel ) mine is grey and flat due to a a lager person sitting in my car over the weekend and ripping it totally off :twisted: :twisted:
can you still buy this part
or
get it repaird ?
Put a pic up if you can and/ or quote a part number.
Also say which side it is from as it may be handed.
hi nick
will do tomorrow i looket on the delorean.com and they don,t list it but i put a photo up tomorrow
If it is the part I am thinking of, I may have one as a spare but in black. It could be sprayed grey. I will have to have a look as the spare I have may be the panel where your elbow touches when seated.
NickT Wrote:If it is the part I am thinking of, I may have one as a spare but in black. It could be sprayed grey. I will have to have a look as the spare I have may be the panel where your elbow touches when seated.
I have half a tin of Ed's grey trim paint if it helps!
hi both
it sounds like a plan just been speaking to ed and he sais that the states are very low on them but he has a few if i can,t get it reapried in some way as i said i will post on here tomrrow thanks for the help guys...... :lol:
Hi Glen
Had a real job trying to sort these out on my car.
NONE available world wide.
However you can get them repaired/retrimmed by Richmond and James on 02392 266899.
Check out my photo's on the "Grey vinyl" post. Panels look like new.
You'll need to follow the tech tip in last years club mag on changing your rear speakers to get the panel off safely.
Good luck.
PS if you have any probs just email me and I'll talk you through it.
Best Regards
hi there
mine will be a liitle harder to change than a normal delorean as all the bttf kit is in it but the car will be off the road for two weeks know due to the under wheel convertion been done plus a total new revamp in side but i have to have it back on the road for june as it going to disney to a show for the doc club :lol: :lol: :lol:
p.s
plus going to see paul in hospital :roll:
Glen & Sam Wrote:hi there
p.s
can you give him my regards and drop him a mike hammer dvd to cheer him up LUV TT
Darren C Wrote:Had a real job trying to sort these out on my car.
Yep, what Darren said. Quite a few bits of interior trim are now seem to be getting VERY scarce
I can't remember your VIN Glen but I think it's somewhere in the 3XXX range? If so I'm guessing you're after the early type trim piece with the with the separate vinyl-stiched arm rest extension bit. You may have to go down the route of getting a used one matey, or possibly a repair to your existing one?
Still not sure what piece you are talking about, and where it is damaged, any chance of a photo Glen?
James RG
p.s
'Under wheel conversion ' sounds interesting ...any further info Gleny
