22 Mar 2008, 07:08
While I was driving happily in the D today, the speedo suddenly dropped to zero mph (while still at 30mph)... and I though, oh bugger, it's not the angle drive/ the speedometer right!? I gave it a few more miles and hopefully it will return to normal again, but it didn't.
So here is the proceedure to check whether it's really a speedo nightmare:
1. Unscrew upper speedo cable at the lambada counter side
2. Turn the centre core of the speedo cable (quite quickly) and see if the speedometer flicks up or down lightly. This will confirm if your upper speedo cable or the spedometer is working. (Luckily, mine's working )
2a. If the above (step 2) does not make the speedometer move at all, then it's highly likely that the upper speedo cable or the speedometer is faulty, and you should check on these items more carefully to confirm.
Continue below if step 1-2a confirms that the checked parts are still working.
3. Screw the lower speedo back onto the lambada counter.
4. Jack up the front of the car
5. Turn the front wheels to the right (you could also remove the front left wheel for easier access)
6. Unscrew the lower speed cable at the angle drive side
7. Turn the centre core of the speedo cable and ask a friend to see if the speedometer flicks up or down lightly. This will confirm if your lower speedo cable, lambada counter, and the spedometer are working. (Luckily, mine's working )
7a. If the above (step 7) does not make the speedometer move at all, then it's highly likely that the lower speedo cable or the lambada counter is faulty, and you should check on these items more carefully to confirm.
Continue below if step 1-7a confirms that the checked parts are still working.
8. While the lower speedo is removed from the angle drive, rotate the front driver side wheel (or the hub if your wheel is removed)
9. Look inside the angle drive, where the lower speedo cable connects to, and see if the inner core rotates (while you are rotating the wheel/hub).
9a. If the above (step 9) does not make the inner core of the angle drive move at all, then it's highly likely that the angle drive is faulty, and you should remove it from the hub and do a more detailed check to confirm.
Continue below if step 1-9a confirms that the checked parts are still working.
10. If all the above is done and it appears everything is working (which is my case), put grease on all ends of all inner core of the speedo cable and assemble everything back together.
11. Confirm all screws/caps are tight and the speedo cables are secure and are not "clamped" by other interior/exterior parts.
12. Give it a test drive and problem may be solved! (Which is what happened to me!)
13. It's best to test the speed reading with a known source (e.g. following your other car with your D with a known speed, or use a GPS speedometer).
14. Hopefully this is the true end of the speedometer nightmare!
In my case, after doing all these 14 steps, the speedo nightmare is solved without any replacement part.... So far the speedo system appears to work just fine. The problem was probably caused by a stucked speedocable. I hope this is the true end to the speedo nightmare
Hope this helps anyone who expreience similar problem. :wink:
