12 Nov 2006, 22:26
I drove a 200 mile trip yesterday and noticed that the steering felt like it was tugging on something whilst on the return leg. :?
I raised the car onto axle stands this afternoon and was pleased to find the cause but also realised how serious it could have been if the aircon hose had ruptured. :oops: It is item 18 part number 100748 as seen at the below link.
http://www.delorean.com/dmcstore/ViewPage.asp?PageID=83
It is surely no co-incidence that the installation of my stainless steel brake hoses that were fitted only the other week or so ago could have potentially disturbed and finished off what must have been a weak rubber sleeve that holds the aircon pipe in place. As the rubber sleeve split it dropped the aircon hose thus placing it so that the threaded end of the bolt that links the upper steering shaft to the steering column end caught on the hose with each turn of the steering.
The offending bolt:-
http://www.delorean.com/dmcstore/ViewPa ... popup=true
source page :- http://www.delorean.com/dmcstore/ViewPage.asp?PageID=68
The first image shows how the rotation of the bolt has shredded the rubber sheath revealing the layer below. Fortunately the pipe is still intact and there has been no leak. I have never seen a cross reference of this pipe but curious to know how much material there is separating the refrigerant from the outside world...
![[Image: view2.jpg]](http://i93.photobucket.com/albums/l55/Chris_Von_Bron/view2.jpg)
The following two images show what I believe to be the torn rubber sleeve hanging below the aircon hose. I have hoisted the coolant hose up out of the way so that you can see the damage on the hose and how in the lower position it was being shredded.
![[Image: viewofeverything.jpg]](http://i93.photobucket.com/albums/l55/Chris_Von_Bron/viewofeverything.jpg)
![[Image: view3.jpg]](http://i93.photobucket.com/albums/l55/Chris_Von_Bron/view3.jpg)
I have circled the offending bolt in the following image, but the camera has not focussed on the damaged material.
![[Image: view4.jpg]](http://i93.photobucket.com/albums/l55/Chris_Von_Bron/view4.jpg)
I was going to find a suitable rubber compound to repair the protective part of the pipe. I have moved it around gently to do the photos and determine the extent of the damage. It has not leaked.
Can anyone clarify how much pipe there is between the gas and me?
Even if it had leaked how can you easily replace this pipe? It is tucked between the pontoon and the chassis. The metal ends would surely mean that you cannot simply lubricate the pipe to aid pulling it out. Would this really mean a chassis/pontoon separation or John Hervey's twin piece version?
I haven't found the replacement supportive sleeve in the manual yet, but would anyone be able to send me a photo illustrating the correct mounting/support of the aircon pipe?
Unless someone has a better suggestion I was going to repair the pipe and then re-mount it.
Thanks in advance?
Thanks in advance?
