25 DMC Parts (12 new / 13 used) some are rare items, auctions end Sun 21st March 21
25 DMC Parts (12 new / 13 used) some are rare items, auctions end Sun 14th March 21
I’m having a clear out of new/used parts.  Some of these parts (new and unused) are no longer available from any of the vendors.  All of the items finish in the evening of Sunday 21st March GMT.  Shipping is free to all UK buyers.  International buyers are welcome, but please contact me before bidding so that you’ll know what your shipping rate will be.
New
111388            Hood Edge Strip 44" –Side
https://www.ebay.co.uk/itm/164754021612
105542            Brake Servo
https://www.ebay.co.uk/itm/164754020875
100289            Stainless Brake Servo Booster Mounting Bracket
https://www.ebay.co.uk/itm/164754019954
108534            The DeLorean Go Silicone Rubber Door RH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164754019409
108533            The DeLorean Go Silicone Rubber Door LH Fixed Glass Perimeter Seal
https://www.ebay.co.uk/itm/164754018757
106130            angle drive
https://www.ebay.co.uk/itm/164754017387
108737            hood seal
https://www.ebay.co.uk/itm/164754014927
106781            No Drip Tape
https://www.ebay.co.uk/itm/164754012083
100701            LH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164754009955
100702            RH OEM NEW belt and OEM NEW receptacle inc OEM NEW plastic cover
https://www.ebay.co.uk/itm/164754007426
105085            OEM EXTERIOR MIRROR ADJUSTMENT SWITCH
https://www.ebay.co.uk/itm/164754004498
Evaporator Protector Mesh
https://www.ebay.co.uk/itm/164754003047
Used -    All of the below are original OEM 1981 parts from an Oct 1981 build
102753            Clutch pressure plate and clutch
https://www.ebay.co.uk/itm/164754024834
100701            LH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164754001098
100702            RH OEM belt used and NEW OEM receptacle not inc plastic cover
https://www.ebay.co.uk/itm/164754000108
106720            RH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164753999672
106721            LH REAR SPEAKER BRACKET
https://www.ebay.co.uk/itm/164753999184
108288            OEM Cigar Lighter complete with illuminated ring
https://www.ebay.co.uk/itm/164753997384
110523            Console Cover grey
https://www.ebay.co.uk/itm/164753996899
110521            Console Tray grey
https://www.ebay.co.uk/itm/164753996622
105610            DeLorean DMC-12 OEM Pair Of Dummy Switches
https://www.ebay.co.uk/itm/164753995006
https://www.ebay.co.uk/itm/164753996306
100169O         OEM drive shaft
https://www.ebay.co.uk/itm/164753992145
118702            Rear wheel (hub area needs repair)
https://www.ebay.co.uk/itm/164753991325
100817            Lamp Delay Unit
https://www.ebay.co.uk/itm/164753990829
Back To The Future related items
AOSHIMA Amerang motorised Back To The Future Part 3 DeLorean – Built
https://www.ebay.co.uk/itm/164753986385
Back To The Future – SMITHS – Board Game 1985
https://www.ebay.co.uk/itm/164753984812
Aoshima Back To The Future Part 1 DeLorean 1:24 Scale (incomplete)
https://www.ebay.co.uk/itm/164753986875
Aoshima Back To The Future Part 3 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164753989196
Halcyon Back To The Future Part 2 DeLorean 1:24 Scale
https://www.ebay.co.uk/itm/164753987378
If you have any queries, please message me via the listing on eBay.
Best wishes
oops, I can't correct it but the end date on this auction run is Sun 21st March, not 14th.
