New look headlamps!
Fancy a new look for your DMC? Check these out-they'd look great alongside the black grill! :lol:
Are they any good for RHD?
BMW X1 4X4 Auto.
MG ZS EV Plug in (on order)
I'm no expert on headlamps, but looking at the lenses they don't have any directional lense thingys on, so I assume that the guard around the bulb must have something to do with the light direction for road use-a lot of modern cars have clear lenses and maybe this has something to do with the bulb, maybe it can be rotated in its fitment to effect for RHD.
I'll look into it Chris, I will contact the seller and check it out, they would look neat on a DMC though! 8)
I think, and someone with MOT knowledge might have to check this, but I'm sure I've heard/read that
cars with HID/Xenon headlights must also have self leveling function and also headlamp washers fitted to
be legal in the UK.
Claire  - DOC-UK Treasurer
DOC170
Yeah, my Laguna had optional Xenon headlights and an automatic headlight levelling system was part of the setup with headlight washers-not complicated but it's purpose was to keep the Xenons at the correct height to avoid blinding oncoming drivers, might be a problem as there was a linkage from the front suspension to the light unit, I doubt if we could retro fit this type of system to a DeLorean. Sad
This chap (Daniel Stern is a guru of car headlights) http://www.danielsternlighting.com
I bought Cibie's from Dave Howarth four years ago and one of the bulbs has just failed so was looking for advice as to how I can legally put out the most light from the existing units so I emailed Daniel above at dastern@torque.net and he was very helpful (he's okayed me to share his feedback)
Quote:Well, the brightest regulation-wattage (E-marked, road-legal) H4 bulb is this one:
http://www.powerbulbs.com/store/categor ... ing/h4-472
(reliable UK vendor).
Do note the 165mm x 100mm rectangular lamps are quite inefficient no matter what bulb is in them. You can do very considerably better whilst retaining full road legality with this full-LED headlamp made in Wisconsin by JW Speaker:
http://www.jwspeaker.com/products/headl ... uct=100160
http://www.jwspeaker.com/products/headl ... ngular.pdf
They're quite exceptionally good (and they are the only LED headlamp in this size format worth considering; there are others on the market, but they're all junk). You'd want to contact the maker and ask, but last time I checked they were able to furnish them in E-marked, left-traffic configuration with inbuilt sidelight.
NB most garages in the UK will tend to aim the dipped beams far too low. See if you can get a cooperative garage to set the dipped beams to 0.7% declination rather than the 1.3% to 2.0% they will typically tend to use. The 0.7% figure is within allowable MOT range and gives MUCH better seeing distance without running afoul of glare control regulations.
Best DS
Hi Daniel,
Thank you for much for the replying and your invaluable information.
Before receiving your reply I had come across the below whilst researching various options but didn't see anything about testing/reviews:-
http://www.horizonleds.co.uk/headlamp-c ... -dual-beam
I suspect that even if the Cree's are good they will be hampered by the existing inefficient halogen based unit that they would be being inserted into i.e. it was never designed for output of this type of light/design of bulb... would this be right?
As it stands I'm tempted to go for the Philips Xtreme halogen bulbs that you have recommended as I suspect the Speaker units will become cheaper over time? My existing enclosures are only four years old so it would be shame to bin them at this stage...
What are your thoughts of the Cree units above?
Kind regards,
Here is Daniel's response when the below were suggested:-
Quote:http://www.horizonleds.co.uk/headlamp-c ... light-kits
No. No, no, no, no, no. *NO.* Absolutely not. This is a scam/fraudulent product, not even remotely capable of producing even a minimally adequate, safe amount of light in an appropriate beam distribution. It does not matter whose name is used (usually fraudulently; "Cree", etc.) or the particulars of the (bogus) claims made. DO NOT buy these.
Best DS
As my Cibie enclosures still have some mileage left in them I've ordered a set of H4 bulbs that Daniel recommended although the LED JWSpeaker set he recommended look great and I'm sure they'll come down in cost as my quick google from one supplier showed $1300 for the set of four and that's before customs/shipping Shock
In summary if you want to go LED with your headlights and you use your car enough to justify the outlay then it looks like the JWSpeaker units would be the way to go based on Daniel's (and other feedback I've found) advice/experience...
Vin 5255 Grey, 5-speed
The ones being offered above are HID not LED. The beam pattern is generated by the lens not the glass front so *might* be okay. My Mazda's HID's throw a more or less flat horizon with a high intensity spot in the middle.
Can we find out hat he said about the HID ones? Big Grin
They might raise a few eyebrows :lol:
