Threads: 5
What is needed to disconnect in order to lift the body off the frame?
1981 DMC Delorean VIN 1598
2004 Peugeot Partner
x1979 Pontiac Trans Am
x1975 Chevrolet El Camino
x2002 VW Multivan
x2001 Peugeot Partner
x2007 Peugeot 307
x1995 Fiat Punto S55
x1966 Lincoln Continental
x1974 Plymouth Satellite Sebring
x1982 Porsche 944
x1988 Audi 100 2.0E
x1986 VW Jetta GL
x1982 Audi 80
Threads: 22
Body bolts
Steering shaft
Brake/clutch lines from reservoirs
Handbrake cables
Rear fascia
Electrical connections at bulkhead
Battery cables
Water hoses to expansion bottle
Water hoses to heater matrix
A/C Hose going to condensor
Gear knob /Selector
Throttle cable
Front loom where it bolts to the frame for earth
Fuel tank filler hose etc
Those are the main ones
Vin #4087
Threads: 5
Thanks alot! If there is anything more, feel free to shout it out!
x2002 VW Multivan
x2007 Peugeot 307
x1982 Porsche 944
x1988 Audi 100 2.0E
x1986 VW Jetta GL
x1982 Audi 80
Threads: 22
There could be more but you will find those things making the funny noises when you try to lift the body off
Vin #4087
Threads: 137
There'll always be something you miss, but that seems a pretty good list!! You'll soon find the maximum tensile strength of anything you forget!
If yours is an Auto then you'll also need to disconnect the governor computer socket and detach from the bulkhead...
Threads: 5
Its a manual, but thanks anyway!
