re any uk supplier of oem spark plug wires?
Hi
does anyone know where i can get bougicord wires?.
i tried a motor factors non oem set, and it did not have the rubber long cover that stops crud dropping in the hole!.
thanx
I know a couple of people have basically swapped the boots over to their new wires, if you use a bit silicone spray to pop them of / on easier.
Mike
my set were off a renault 30 as i recall they were slightly longer than standard but im well happy and they were around £50 TT
