upper strut bar
Last year we did test a upper strut bar for the car on the oval Track in Houston.
This strut bar give a lot better feedback and less body roll.
It is a simple bold on construction, for the installation you have to remove the carpet.
Thane you have 2 options, make 2 small holes in the original carpet, ore take the new one and save the old one.
The bar use special joints , to adjust the length.
Regards Ed Uding
http://www.delorean.eu
http://www.delorean.eu/product_info.php ... cts_id=198
[Image: dsc05786hm4.th.jpg][Image: thpix.gif]
Hi Ed,
Looks good.
Can you still lift the carpet and get the spare wheel out?
Kind Regards
D
In case you neat the spare wheel you use the 17 mm key, you have to remove only the bold on the RH side.
A small job for better road performance.
Regards Ed
www.delorean.eu
