helicoil in block
hi all has anyone had to helecoil the block for the head bolts i have a couple what are a bit suspect and would like them all done
thanks tt
found the heli-coils sizes are m12 x 1.75 just for everyones info TT
You don't seem to be having much luck !
Either that or you just want to be sure Big Grin
i know nick i made a mistake and i have no problem admitting it, the head bolts have to be oiled up before instalation before you torque up, a useful bit of info in case anyone has the pleasure of an engine rebuild. But at least i will have 2 running engines one with turbo one without, so i worked out i might be able to install both and get some decent power :lol: TT
