11789 firing up at last - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: Members Cars (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: 11789 firing up at last (/showthread.php?tid=5828) |
11789 firing up at last - SpudMurphy - 28 May 2018 Effort #1 - it fired up and ran on 3 or 4 cylinders . Initially I was ecstatic thinking an adjustment here and there would get it all ok? I posted on here saying that it was "Alive", well be that as it may, but it was "under the weather"! Effort #2 I got nowhere - wouldn't even run! Effort #3 Investigation showed that a PO had put in the distributor "a lot of" degrees out . the valve clearances were tight. and (my fault) a vac leak was spotted on the w pipe - which was not seated correctly and a turn of the distributor - it caught and it burst into life and revved nicely too. Will now do some minor work to the engine - check for leaks - swop the rad and expansion tanks over for the new ones I have - onwards and upwards or in my case downwards as I will take the car off the concrete blocks. https://youtu.be/5Ca2B5Bo_m4 RE: 11789 firing up at last - TristanC - 28 May 2018 Excellent work !! She lives!!! Well done. I bet that was somewhat of a milestone right there. ![]() I’ve embedded your video here for you: RE: 11789 firing up at last - SpudMurphy - 28 May 2018 (28 May 2018, 10:04)TristanC Wrote: Excellent work !! (28 May 2018, 10:06)SpudMurphy Wrote:(28 May 2018, 10:04)TristanC Wrote: Excellent work !! RE: 11789 firing up at last - TristanC - 28 May 2018 Ahh yes, getting her off the blocks.... that was just last weekend for mine! Awesome too ![]() Best of luck, she’s coming along brilliantly |
