MOT Fail :( - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: MOT Fail :( (/showthread.php?tid=3048) |
MOT Fail :( - Rich Hanlon - 14 Mar 2011 Three guesses what single item it faield on? Re: MOT Fail :( - stunned_monkey - 14 Mar 2011 Handbrake Steering play Emissions Re: MOT Fail :( - Rich Hanlon - 14 Mar 2011 Right first time - Give the man a blue Peter badge! Would be an interesting statistic if HM Govt is storing MOT results against Manufacturer anywhere - one might suspect a skew towards handbrake-related issues against DMC! (Or it's most probably 'Other' in ther drop-down lists!!) So, This week, I shall be mostly fixing my handbrake AGAIN! It's amazing that they're SO sh*t, given that they only have the same basic components and function as any other disc-operated handbrake system - Ratchet, cable, and a thing that causes one thing to grip another thing, increasingly tightly! Re: MOT Fail :( - stunned_monkey - 14 Mar 2011 The problem is the mechanism that's meant to ratchet -in- to take up wear in the pads actually slips and causes the lever to apparently loosen over time. Adjust handbrake an ddon't use it till you'r eont eh rollers Also had trouble in the past with cheap pads, after all the handbrake pads never really get a chance to bed in. Re: MOT Fail :( - Guinney1971 - 15 Mar 2011 I cant believe that the same MOT tester that failed Flopsy's handbrake (that will hold on the hill outside RichH's house), passed one of our Cavalier's handbrake - and that wouldnt hold on a hill!! WTF? :roll: |
