what size banjo bolt fuel line to distributor - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: what size banjo bolt fuel line to distributor (/showthread.php?tid=2299) |
what size banjo bolt fuel line to distributor - steve.s - 10 Jun 2009 Hi does any one know what size the banjo bolts is at the end of the fuel line that connects to the fuel distribution unit?. is there anyone in the UK with these?, as seems points to make a $2 order with delorean.com. thankyou Steve vin 1621 Re: what size banjo bolt fuel line to distributor - Rich H - 10 Jun 2009 Don't know off the top of my head, but I can send you one if you need. Re: what size banjo bolt fuel line to distributor - steve.s - 10 Jun 2009 hi thankyou...have you nos?. i could paypal over some £££'s for it!. mine has been tightened and the hexagonal bit is slightly damaged so wil not seal so i have a bit of petrol leaking out. have changed the copper washers (but they are a bit wide and i don't think the fit is great. so i thought i would change the banjo bolt and washers. the fuel line is fairly new. trying to sort for the MOT! thanx Steve vin 1621 Re: what size banjo bolt fuel line to distributor - Rich H - 10 Jun 2009 They are the larger size for that fitting, 12mm I think I have a good used one I can send you. Do you have copper washers? Re: what size banjo bolt fuel line to distributor - NickT - 10 Jun 2009 14mm Re: what size banjo bolt fuel line to distributor - steve.s - 11 Jun 2009 sorry here is an update. i managed to locate a diesel place a mile from the office and purchased a 14mm bolt. but just gone to the car to fit and it is 12mm !. so back in the morning to try and change it. the old one is definately no good. thankyou for all your help, and hopefully in the morning i can get the 12mm one. Regards Steve Re: what size banjo bolt fuel line to distributor - NickT - 11 Jun 2009 Sorry Steve, I thought you meant the other end of the pipe that goes on the CPR. Glad you got one anyway. I have a small box full of banjo bolts collected over the years. Nick. |
