29 Sep 2006, 23:22
Ok here goes
I took my dash apart today to start my new stereo project. Once finished I put everything back together the way it was before (or so i thought)
I have lockzilla and when you lock or unlock the car it flashes all the outside lights and lights up the headlight switch, hazard switch and the instrument cluster/speedo etc. This keeps all these lights on for about 30 seconds and then switches them off. Usualy once I put the key in and turn the headlights on the speedo lights up and the headlight/hazard lights up too. So once I had the dash back together I switched on the headlight switch to test it and it didnt light up nor did it turn on the dash lights - it did turn on the headlights but it ALWAYS turns on the little bulb in the switch and the hazard the funny thing is that it still turns on when I lock or unlock the car, so if it can do it then why cant it do it when I actually press the switch in??
Every other light works including headlights and breaks so why does this not work?? Rheostat WAS working when I took the dash apart but there isnt even any power going to the rheostat as I have tested the wires running to it with a multimeter and tried to connect them both together but this does not work. All the warning lights on the binacle work just not the lights controled by the rheostat. When I first put the headlight switch back in I remember it lighting up when I pressed it on, it was only when I went to reconnect the rheostat that it all stopped working.
Where does the power come from to control the rheostat and light up the dash and the headlight/hazard light as I feel I have blown a fuse or pulled a wire out, but how does it still work with the lockzilla????
IDEAS PLEASE!!!!!
p.s ALL FUSES INTACT IN FUSE BOX (checked them first)
IDEAS PLEASE!!!!!
