20 Jan 2020, 17:25
22 Jan 2020, 21:46
Looking good mate, though I still think a new chassis would have been the best route! How does the rest of the chassis look?
23 Jan 2020, 02:27
It's coming on beautifully, there are lots of repair sections under professional fabrication and I've seen some regular updates of the ongoing work which I'll share once it's finished. I'm very happy with the results, and it'll still be 'my' car when it's done - I think I would have struggled to convince myself it was fully my car if it had a replacement chassis, and this way will also work out a fair bit less. Also the new chassis are made to order, not off the shelf, so the lead times would have been very similar.
23 Jan 2020, 07:27
I can see both points of view here. I tend to think more like Richard. When faced with all the stuff that needed sorting on MGJ, my first choice was to get things restored. Water pump via Dave H, brake servo's, etc. At the same time I'm happy to upgrade to better technology of Safety. The chassis is a big chunk of the car, and a safely item....it needs to be right and I'm sure it will be now.
I'm happy keeping my slightly dented and marked stainless panels...i'm not having them 'perfected' by Chris N. Much like the front and rear facias ...they really need re-painting, but they look pretty reasonable and are stopping as they are.
Future generations and owners can make their own choices. Things are only 'original' once.
23 Jan 2020, 11:57
Yeah, that was my feeling... It is being restored in the same jigs as the new ones are built in, using fabrications from the same supplier, so effectively it will be as new, but retaining the good sections of my original chassis, with various improvements including a complete new front frame extension, which was worse than anticipated, so we elected to replace it completely. Apparently these have previously been replaced with the body in-situ by some owners ?. That must take some doing and no idea how you would get to weld the top on properly.
I'm presently coming down on the side of galvanising it afterwards...
23 Jan 2020, 21:57
Quote:Yeah, that was my feeling... It is being restored in the same jigs as the new ones are built in, using fabrications from the same supplier, so effectively it will be as new, but retaining the good sections of my original chassis, with various improvements including a complete new front frame extension, which was worse than anticipated, so we elected to replace it completely. Apparently these have previously been replaced with the body in-situ by some owners ?. That must take some doing and no idea how you would get to weld the top on properly.Ahh right so it's over in Norfolk being done by the chap you met at the NEC then? Is he happy for his contact details/company details to be posted on this forum to help others in a similar situation as yours or whom may be after a new frame?
23 Jan 2020, 23:59
He seemed a very nice and capable you man....Didn't seem tied to anyone, just trying to use his skills to make a living...But I'm sure Richard knows more than me......
25 Jan 2020, 11:28
Yeah, he's spot on, and doing some great work. I'll share more when it gets to the end and I can post some 'before and afters'.
18 Feb 2020, 00:15
Spot of engine rebuilding while the chassis is away!![attachment=736]
This is a few weeks ago. Thanks again to Mr Hutchinson!! [attachment=738][attachment=739]
18 Feb 2020, 08:22
That looks absolutally lovely....Richards....not over the top, just spot on. Factory fresh.
I now realise how much easier it must be to get it looking good, when you can get all the way around it.
It makes me think again about setting-to with my spare (but not running) engine....the one I removed from Frenchy, many years ago.
18 Feb 2020, 10:25
Thanks very much Chris! I still need to do a similar tidy up around the autobox and transmission cooler. Exhaust manifolds also still to fit, skimmed nice and flat and ready to go.
21 Feb 2020, 19:04
I'll deffo be interested in speaking to the chassis refurb dude when the time comes, although I cant see work starting on #2292 anytime soon. This will be another year of building work, maybe we'll be able to start stripping in down next year. Its been of the road for 3 1/2 years, another couple won't make any difference........
21 Feb 2020, 23:07
[attachment=742]
Hi Claire,
has my chum Iain been it touch yet? He's writing a story for a car mag about converting classics into Electric cars. He might like a chat with you and Phil.
(my regular can doesn't need converting!)
Sorry to divert the thread.....
Hi Claire,
28 Feb 2020, 00:34
New exhaust studs, newly machined manifolds, brass hex nuts. Looking good!![attachment=745][attachment=746]
The chassis, incidentally, is now away for blasting, galvanising and powder coating. Here it is with its new front frame extension :-))[attachment=749][attachment=750]
28 Feb 2020, 11:37
Nice work on the chassis! What a lot of surface rust there!
Those are some LOOOONG manifold bolts you have there! Brass ones too! Where did you get them? And how long are your studs to accomodate those!?
