28 May 2018, 09:59
Effort #1 - it fired up and ran on 3 or 4 cylinders . Initially I was ecstatic thinking an adjustment here and there would get it all ok? I posted on here saying that it was "Alive", well be that as it may, but it was "under the weather"!
Effort #2 I got nowhere - wouldn't even run!
Effort #3 Investigation showed that a PO had put in the distributor "a lot of" degrees out . the valve clearances were tight. and (my fault) a vac leak was spotted on the w pipe - which was not seated correctly and a turn of the distributor - it caught and it burst into life and revved nicely too.
Will now do some minor work to the engine - check for leaks - swop the rad and expansion tanks over for the new ones I have - onwards and upwards or in my case downwards as I will take the car off the concrete blocks.
https://youtu.be/5Ca2B5Bo_m4
