Full Version: Indicators/ turn signals
Looking for some pointers ,
Indicators work some times , lots of noise from the relay in the fuse compartment , changed it and same issue , also when they work the opposite side also seems to blink slightly , hoping that it is a ground ?
Have you checked the lights, mine where all rusted up ? You can clean them with some sandpaper if necessary.
Be careful when removing the indicators and putting them back in place, the plastic tends to crack easy.
