26 Jan 2015, 16:15
Project Flux update pics. After about 4 days solid work, these are coming on nicely!
First front box out of the mold.
Second front box out, time to go again for the roof boxes!
All plates plasma cut in stainless steel to go with the car. They are usually mild steel and tend to need a buzz off from time to time but these will be brill! Solid 3mm plates too.
Testing the size of the plates on the rear boxes.
Time to take the palm sander to the top side of the casts to clean them up and remove the slight warp on the front box.
All boxes were prepped firstly with grade 80, then 180s followed by some 400s and some scotch for a perfect finish. Ready for etch primer!
Cheeeeeese!
Once etch primed, I decided to do something a little different and add texture spray which turned out fantastic!! They have a really nice grainy/mottled finish and look really professional. I then added the correct primer with the slight blue hue, followed by some metalized blue dust coat to really give a nice finish!
Here are the boxes in normal light
...and here with flash which gives a better impression of that blue metalized coat.
I began drilling the stainless plates (had to use cobalt bits and a pillar) and added some excellent quality socket bolts with a black coat. Drilling 104 holes = days.
Stored away ready for when I finally get all the plates done so I can then drill into the boxes perfectly!
I also decided to mold the plugs right into the boxes. The resin captured the small serial number which was nice, they just need painting black when I'm done with the plates. These things are SERIOUSLY hard work to get to to this standard, unlike the nonsense Video Butthead sends out :roll:
Cheeeeeese!
