05 Jan 2015, 11:31
I'm currently in the process of refreshing my rear suspension, and soon to be putting it all back together. I've stripped everything off the car (caliper, hub, upper/lower links, trailing arm), and now need to look at putting it back together. The workshop manual states that fasteners must be torqued with the car resting on it's suspension.
Am I correct in thinking this applies specifically to;
I assume the other fasteners can be torqued whilst the car is jacked up? Or do I have to torque the Trailing arm bolts with the suspension loaded also?
- Frame to link fasteners (upper + lower)
- Link to hub fasteners
- Shock to hub fastener
- Shock to frame fastener
