02 Mar 2007, 01:06
02 Mar 2007, 11:17
Evo Stick
05 Mar 2007, 15:12
Thanks Dan,
Tried it at the weekend, after taking the majority of the old stuff off the hood and the rubber. Its trying to stick, but still coming away. I will retry after i have both surfaces totally clean.
05 Mar 2007, 17:17
If I remember rightly about Evo-stick you have to not only ensure the surfaces are clean but also that you wait around 15 minutes from applying the glue to both sufaces to actually fusing them together.
I used this stuff for the carpet on the hood that covers where the fuel door should be and also on part of the seal that runs around the hood. I did this years ago and it still looks great.
05 Mar 2007, 19:01
The glue you need is called Seriously sticky stuff by Evo stik. Comes in a black tube. Any DIY store will do it. Just aply and use a couple of pegs to hold it. Go in and watch Top gear or Scrap heap challenge and when thats over your glue will be done. You can buy it in small tubes or big silicon gun type tubes. I stuck my window back in with it. Glass to stainless not bad eh. I don't know what the solvent for it is though so be careful with it. Basically it sticks like 541t to a blanket. I use nothing else now after haveing searched for years trying to find the ultimate glue.
06 Mar 2007, 00:16
Yeah you have to leave it for 15 minutes and do a small run at a time, no longer than 15 cm.
Forget trim tapes there just no strong enough
