I've started a blogg to document how I found and (hopefully soon) imported VIN#10719.
http://delorean-dream.blogspot.com
In it I hope to take people through the process of finding, importing and finally enjoying a DeLorean.
Let me know what you all think.
Pish.
(Just kidding!)
Keep it going, i'll be interested in reading the updates, and experience throughout the whole affair. :wink:
good work, and congrats on the car, cant wait to see it when you get it over here
Cheers both, I'll keep adding to the blog and on here, keep you all posted. Hopefully it should all go smoothly.
Well, been busy with 10719. The following have all been done:
fixed handbrake.
New master cylinder and bled brakes.
New washegr motor.
Cleaned off ALL black gunk from the underside - messy and unpleasant in the extreme!
Treated flaking epoxy and painted with POR-15.
New UK lights on the front.
Rear fog light INSIDE the original light cluster WITHOUT any modifications to the PCB.
New lower front springs, and new rear springs. (Chris N)
SPAX shocks all round (Chris N)
New trailing arm bolts. (Chris N)
New oil filter and new oil.
New clutch, press plate, throw bearing and rear seal. (Chris N)
New door struts. (Chris N)
Couple of dents removed from the body work (thanks to Chris N)
Plus all gears and linkage sorted bu Chris as well.
So, getting there. Just started on the interior. Removed all the trim parts and starting on the carpets. Should have it all done by the summer, fingers crossed.
Loads of details on the blog at
http://www.delorean-dream.blospot.com
Also experimented with making a laser cut/engraved key ring...
liking those keyrings, I can see you getting orders for those with
people's vin numbers on
