12 Jun 2009, 23:58
Right - here's another one of my problems. I removed my new mats today and found that the passenger footwell was soaked. It wasn't wet in Norfolk, so it must have been from the torrential rain on the journey back down (it's been under a cover since).
I spoke to Dave H on the phone because he'd mentioned a problem to me before where the little hose that drains out onto the fuel tank gets blocked and then the fan motor fills up with water and leaks onto the floor. I blew into the hose at the end over the fuel tank, and while it wasn't completely blocked I'd have quickly died if I was relying on it to breathe air underwater. Dave H then suggested to take the 3 screws off the bottom of the fan motor (I think this is what it is, upside down above the passenger footwell, next to the side of the car) so I did that but found it was sealed on and I didn't fancy cutting it off.
After having trawled the US forums it seems that there's another drainage bit that can get blocked - this is about an inch across, and is a hole above the fuel tank which you can feel if you take off the spare wheel cover etc. Apparently this is the one that rain water drains through, the other is the one water drains through when the aircon is on. Have I understood this right? Does this second, 1 inch diameter drainage hole exist? If so I expect this is blocked on mine as my aircon doesnt work (and that fan motor seemed pretty well sealed to have leaked that much water out of it).
The other thing that could be causing it is unsealed screws in the fibreglass underneath the carpet. Is this possible? Do I need to take seats and carpet out and start putting sealant on everything?
Cheers all!
(apologies for the duplicate post, I don't know how many swingers there are yet )
Cheers all!
