06 Apr 2009, 11:39
Well, ashamedly the last time I took "old faithful" out for a drive it was Eurotech last year ! This is no good. I've decided to forget work and prioritise time to re-commission the D in readiness for this years Eurotech. Since Eurotech last year the only things I did was to do the valve clearances and re-shim the fuel distributor to set to book figures. I haven't even cleaned the car since! A couple of weekends ago the oils were dutifully changed (Engine, Diff, Auto Gearbox) and the car taken for a drive. Although she drove with smooth power delivery, straight line traveling, straight line braking etc there are a couple of issues that need to be sorted before I get concreting done on my garage and the car finds its way to PJ Gradys' for some blinging...
1) Auto Gearbox computer - changing gear at wrong revs. Doesn't go into 2nd until 35mph and 3rd until 45-50mph.
2) Air conditioning - although still works the cycle time of the clutch is only 5-7 seconds. Might be time for a re-fill (DarrenC bring your Gas !! No, not that Gas, I mean Air Con Refrigerant!!)
Fixes:
Well, this weekend although on call I had a day without work so I took the auto computer off. Took ages ! I had to position the car over my pit so I could park my other car at the other side as I didn't know how long it would take. It would have been easier if the car was only 30cm to the left.
After stripping the computer apart (nice sealant!) I had a look inside and it was obvious there are 2 capacitors that need to be changed. This is part of the ac-dc converter from speed sensor (alternator). This would explain why it wasn't changing up until the correct speed was obtained. Now, if these popped because of issues with my alternator or due to old age I don't know. I will be changing these to long life tantalum capacitors and doing a couple of recommended mods like de-coupling caps across the op-amps power supply and reverse biassed diodes across the coils. I will also change de-coupling caps across the op-amps inputs and change the zener diode too. Hopefully I will be able to get the lot back in my car tonight if not tomorrow.
2) Fix whenever, not as important.
3) Have a Tikka Balti Curry and a Cold "Old Theakstons" Bottled beer [obviously nothing to do with fixing the car but worth it for the sense of "well-being" ]
I will take some pics if I remember.
ps I got the auto computer circuit diagram and info from DMC Talk.com, very useful article. I will add a link if I remember.
Fixes:
