hi all, i may be buying a 760 volvo on ebay for engine and fueling system. the only thing is,is it an odd fire or even fire and will it matter, its on a d reg any advice thanks tony tt
You could have a look at the distributor cap.
If you look from above and the ht leads are equally spaced (ie 60 degrees from each other, then it will be an even fire.
I am not sure on engine numbers and stuff.
What fire is a standard Delorean? I know mine is the opposite because it has a volvo dizzy.
Dan1986 Wrote:What fire is a standard Delorean? I know mine is the opposite because it has a volvo dizzy.
Oddfire.
Funny they should change them, but my point is they re-made the crank to even fire and then remanufactured new dizzy caps to suit, so really unless the splines dont fit there cant be any reason why they cant be fitted. And i reckon the castings are still the same as well just curious ( not bi lol ) TT
Did you end up buying the 760 tony?
no mate im rebuilding my original engine to put turbo back on. I do know that it will probably blow up but for the cost of a top end gasket set and second hand turbo its gotta be
worth a laugh
TT
I see. Do you have any long term plans for a more permanent job that won't blow up?
not really dan i still have the volvo engine to fall back on but maybe a totally different engine v8 poss, apparently there are a lot of engines that fit on that gearbox, we will see . but standard for me is slow TT
