Hi all not sure if this is really in the right topic but my engine cover release handle (behind the drivers sholder)LHD seems to have brocken it pulls out quite far i think the end in the cab has brocken or came off.i dont think it is the engine cover end would anyone have a diagram on what it looks like behind the pully and if you know if i will be able to get to it from the cab side.
i would appreciate any advice or tips
thanks alot Tyson
Hope this helps!
The best thing to do is take out your near side (drivers LHD) rear light cluster.
You can reach in behind the Number plate and release the engine cover.
Once open you'll be able to see whats gone wrong and take off the access plate (item 32) to the latch assembly.
Good luck
Best Regards
thanks alot darren i will try that hopefully tomorrow great tip about taking out the light thanks alot
cheers Tyson
Once you've got in, if you need a replacement pull-handle then I think Vehicle Wiring Products (In Nottingham) does an identical pull handle kit.
thanks richard i am still waiting to sort it out just haven't had the time to spend on her yet but thanks for the link
kind regards Tyson
Thats all you will probably need. You wont need to screw it all the way in though, well i didnt anyway. Some adjustment may be required to get it right
Its funny that little latch striker looks strikingly familiar as the pins which hold the base of my Christmas tree in place.....
