20 Jul 2008, 12:41
Hello Everyone! Long time no see!
Right, so I got a new alternator from SpecialTauto. Hoping that this will be the last electrical problem of all sorted in one go....
I worked out where the B+ connects to, but I am stuck with where the "L" thin wire is (from the original wires in the car)
The old alternator I have has the following connections:
Ground (via the mounting bolt and such)
B+ (a screw/nut at the back of the alternator)
L (a thin, either red or white wire... i mixed up the two and don't know which is which. It connects to the top of the voltage regulator)
B+ (a thin, either red or white wire... i mixed up the two and don't know which is which. It connects to the top of the voltage regulator)
The new alternator has:
Ground
B+
L
Are there any ways I could work out which of the two thin wires (from the car) is the "L" wire? Or should both be connected to the "L" connection of the new alternator?
I tried measuring them both, but the results confuses me:
ignition off:
both reads 0V
ignition on (engine off):
both reads battery voltage.
Any help would be greatly appreciated!
Many Thanks!
Ground
B+
L
ignition off:
both reads 0V
Many Thanks!
