Has anyone got a good source for these pieces please
Mike
Does this mean your custom stainless system has arrived?
Try DMCH,
Items 18 & 20 on Engine Exhaust parts list,
Studs $1.99 each (a quid)
Gaskets $9.99 each (a fiver)
Even with tax that's cheap as chips and original DMC stock.
Best Regards
bozzzydmc Wrote:Has anyone got a good source for these pieces please
Mike
If it's any good to you I have a few S/H ones you can have.
Is part 18 the m7 stud or one of the m10 studs that holds the cross over pipe ??
Not sure thats the right one but buggered if i can see 12 no studs on the page
Dan1986 Wrote:Does this mean your custom stainless system has arrived?
Will be here soon just trying to be prepared
Thats the M10 one, the M7 ones are part no; 102167
Sorry Mike,
Its item 48 on the cylinder head page. Number as per chris's post.
Sill cheap at $3.95 (2 quid)
Best Regards
I think the exhaust studs are different threaded, m7 to engine block and m10 for manifold nuts.
Item 18 in diagram.
I would recommend 4 studs per port as you don't want any leaks... I'm talking from experience although my system is a different design.
I'm trying to remember where mine came from - I *think* they came from
KMI in London as part of all the headgasket kit - I'm pretty sure they
relate to a Volvo 760 anyway, so it might be worth having a word with your
local Volvo specialist/dealer perhaps???
Mike, on the right are the manifold to cross over pipe studs (M10) on the left are the Head to manifold studs (M7) 102167
