08 Apr 2008, 20:34
Hello my Delorean chums
On operation of the dip headlights (that's two pushes of the dip headlight switch on the centre console) I get the dip (as it should be) AND, for some reason, a dim light coming from the H1 inners also a light from the main beam telltale (blue bulb - instrument panel).
The power isn't coming from the main beam relay because I've tested it by removing the relay an operating the dip beams - i have the same result.
the power might be coming from the dip beam circuit - but where?
I suppose i should test to see whether I'm getting power to the inners by test removing the outer bulbs or the telltale on the panel...didn't think of that.
any ideas?
Dave.
any ideas?
Dave.
